* Model Name : ML-1640
* Version    : V1.01.00.60
* Updated Items
  . Added Watch-dog function
  . Modified the problem that 'Fuser Low Heat Error' occurred after print 3pages for envelope paper
  . Crum Validation 2times check
  . Changed the PVC reset method
  . Applied and Separated the Initial toner count on configation sheet
* Attached Files
  - ML1640_V1010060.fls  : Firmware file.
  - usbprns2.exe       : Firmware update utility
  - ML-1640_Release Note.txt
* How to F/W update.
  1) Connect PC and printer with USB cable.
  2) Turn on the power of printer.(Ready Status)
  3) Drag the f/w file and Drop down on the usbprn2.exe. And then f/w update will be started automatically.
  4) Please wait until end reboot.
*    : ML-1640
*      : V1.01.00.60
1. watch dog ߰
2 .Crumν ùȸ н   õû  1ȸ  ǽϵ
3. Initial toner count   Ʈ ǥ
4. PVCʱȭ  .
5.   3 μ Ŀ Fuser Low Heat Error ߻ϴ
  - ML1640_V1010060.fls   : ߿
  - usbprns2.exe                   : ߿ Ʈ ƿƼ
* Ʈ
  1) PC ͸ USB  ̺ Ѵ.
  2)   ON Ѵ.
  3) ǰ Ready ¿ F/W  巡ؼ usblist2.exe Ͽ  .
    (â  Դٰ )
  4) 5~6   F/W ٿε Ϸ  ڵ  OFF/ON
